Cisco virtual HUB and Cisco as a Radius controller
Translator
Administrator
Administrator
As part of a test lab that I set up, I have a question.
I work with a virtual HUB and Cisco as a Radius controller.
When I'm in the Authorization Profile section, and I try to enter with a mask (as in the image below), and I submit a test request on my virtual HUB, all the characters entered appear (Internal User: Administrator 255.255.255.255).
So I imagine that the values attribute ​ ​ is not taken into account correctly.
Does anyone know if there is a particular way to enter my Values or if we should consider setting up a section of parameters before this entry?
Thank you in advance for your feedback.
What is a virtual HUB?
