Cisco Wireless Access point are not working after TACACS Implementation
chaitu_kranthi
I am unable to access the Cisco Wireless Access point using http(GUI)mode. after tacacs implementation. But i am able to access the same devices using telnet with tacacs user id.
Need some help in this...
10 Replies 10
Farrukh Haroon
Look at the 'ip http authentication' command.
Farrukh
Yes,
The command is already there
if i remove the tacacs(no aaa new-model) from the device then it is working through http also.
It is ip http authentication aaa?
Can you post output of show ip http server all?
REgards
Farrukh
LASAOAP1#sh ip http server all
HTTP server status: Enabled
HTTP server port: 80
HTTP server authentication method: aaa
HTTP server access class: 0
HTTP server base path: flash:/c1200-k9w7-mx.123-2.JA2/html/level/1;zflash:/c1200
-k9w7-mx.123-2.JA2/html/level/1;flash:/c1200-k9w7-mx.123-2.JA2/html/level/15;zfl
ash:/c1200-k9w7-mx.123-2.JA2/html/level/15;flash:/c1200-k9w7-mx.123-2.JA2/html;z
flash:/c1200-k9w7-mx.123-2.JA2/html;flash:
Maximum number of concurrent server connections allowed: 5
Server idle time-out: 120 seconds
Server life time-out: 120 seconds
Maximum number of requests allowed on a connection: 60
HTTP secure server capability: Present
HTTP secure server status: Disabled
HTTP secure server port: 443
HTTP secure server ciphersuite: 3des-ede-cbc-sha des-cbc-sha rc4-128-md5 rc4-128
-sha
HTTP secure server client authentication: Disabled
HTTP secure server trustpoint:
HTTP server application session modules:
Session module Name Handle Description
Homepage_Server 3 IOS Homepage Server
HTTP IFS Server 1 HTTP based IOS File Server
WEB_EXEC 2 HTTP based IOS EXEC Server
HTTP server current connections:
local-ipaddress:port remote-ipaddress:port in-bytes out-bytes
HTTP server statistics:
Accepted connections total: 4
HTTP server history:
local-ipaddress:port remote-ipaddress:port in-bytes out-bytes end-time
100.193.1.240:80 192.168.15.243:14879 389 191 17:16:03 08/04
100.193.1.240:80 192.168.15.243:15112 436 191 17:16:13 08/04
100.193.1.240:80 192.168.15.243:15289 4011 54809 17:18:08 08/04
100.193.1.240:80 192.168.15.243:15488 5596 55155 17:18:28 08/04
Can you also show the aaa method-lists? Are you using the 'default' one for login?
show run | inc aaa
If not, you need to add that to the following command:
ip http authentication aaa ?
Farrukh
Thanks for your reply;
i have tried the command in other access point and it is working there. but now the problem for me is. with the TACACS user name & Password iam able to telnet to the device with full access but using http i am getting readonly access only.
Is somthing i have to add additionally.
Please try assigning privlege level 15 to the admin users in the TACACS server.
Farrukh
the user is already having Privlege 15.the same tacacs user is having full access using telnet for the same device.
Then please attach the AAA/TACACS configs from troublesome AP's CLI and the following debugs:
debug ip http authentication
debug tacacs
debug aaa authentication
Farrukh
I observed that my tacacs user is logging into the device using http but he is getting the Priv-level = 1,the user is already having the Priv-level = 15. please advise me
Aug 5 09:53:29.492: HTTP: Authentication username = 'gkc' priv-level = 1 auth-t
ype = aaa
