Close Port on ACS Solution Engine, posibble?
c.ong
Level 3
Level 3
Hi Sir,
I did a portscan on the ACS solution engine and found the following TCP ports are open on the ACS Solution Engine,
Port - Services
49 - TCPwrapped
135 - MSRPC
1503 - TCPwrapped
1506 -TCPwrapped
2000 - Calbook
2001 - DC
2002 - SSL
2003 - cfingerd
3389 - TCPwrapped
I would like to know whether the ports open above is required for the optimum operation of the ACS SE. If not, I plan to close some of the ports such as 135 and 3389. Please advise the impact if such ports above are close
Thanks.
Delon
amritpatek
Level 11
Level 11
You can block port 3389 which is used by cfingerd and this will not have any impact on the performance of the device. However the ports used by TCPwrapped should not be blocked as they are connection ports used for communication with other hosts.
