Configure ISE 2.1 with MS SQL using ODBC - retrieve Group ID
skutzer
I have a question regarding the use of ODBC in ISE 2.1 to retrieve Group IDs.
In ACS you can get the Result as well as the Group, but as described in this article this is only available in ACS 4.2
                http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-21/200544-Configure-ISE-2-1-with-MS-SQL-using-ODBC.html#anc8
If we want to retrieve GroupIDs for i.E. VLAN Assignment in an Authorization Rule we need to use a dedicated Store Procedure?
Do we improve the Group Retrival for the ISE to be similar like ACS?
BR,
Sven
Craig Hyps
Level 10
Level 10
You can select retrieval of group and other attributes in ISE for use in Authorization Policy rule conditions.
/Craig
Craig Hyps
Level 10
Level 10
/Craig
