Control switch and Routers with Acs or radius for logging and privi
Hi dear Friend and have switch nexus and C2960 and C3750 and router ASR1002X ASR1001X
I need free aces Server that compatible with cisco devices that admin for login auth username and assign Privillage Level to user
any suggestion For this ????
thanks
Mark Elsen
 - FYI : https://community.cisco.com/t5/security-documents/cisco-ise-device-administration-prescriptive-deployment-guide/ta-p/3738365#toc-hId--919282975
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Greg Gibbs
Cisco switches and routers support standards-based TACACS+ protocol. Any TACACS+ server that supports the standard should work, you just need to ensure that whatever policy model is used by the T+ server returns the correct attributes to the device. Examples of those attributes can be found in the ISE guide shared by @Mark Elsen
