CSUtil problem
walderhaug
Running the CSUtil.exe command on and ACS 4.0 installation (Windows server 2003) gives me the following error:
"Can not initialize SchemeLayer"
I tried to register the SchemeLayer.dll with the command "regsvr32 SchemeLayer.dll", but that did not work.
Any good suggestions anyone?
darpotter
Level 10
Level 10
Thats a broken install.
Run the clean utility and re-install.
5 Replies 5
darpotter
Level 10
Level 10
How to run clean utility? What is the problem name. I encounter problem on my installation ot AC3.3.2 while upgradeing to ACS3.3 -? ACS4.1 I think all the configuration or regirstar is in a mess. can assist to clean utility, thanks
The clean utility should be on your ACS CD.
ok got it Thanks,
Any idea what is the cspoll.dat file fail almost completion. any concern on this. It seem work fine after the upgrade, Thanks
