Device Administration for F5 using RADIUS
Bogieboogi1
I´m currently running two ISE appliance on my customer for PoC which will be starting soon.
Currently, I`m facing an issue with some a pair of F5 load balancers.
Policy Sets are fine, on the Radius live log site I can see that the requests are hitting the established rules.
It chooses the right Authentication set, Authorization set as well as the Authorization set.
The point here is that I`m not able to get a command shell prompt after entering the credentials. It stays empty and after some time it requests the password again.
My Authorization Profile has the following attributes :
Access Type = ACCESS_ACCEPT
F5-LTM-User-Role = 0
F5-LTM-User-Console = 1
F5-LTM-User-Info-1 = Administrator
F5-LTM-User-Shell = enable
F5-LTM-User-Partition = Common
I running out of ideas currently. Loadbalancer shows the following log:
Aug 17 08:40:31 lb-a1s-hcpp-01 err sshd[3301]: pam_radius_auth: RADIUS server 147.204.66.88 failed to respond
Aug 17 08:40:34 lb-a1s-hcpp-01 err sshd[3301]: pam_radius_auth: RADIUS server 147.204.66.88 failed to respond
Aug 17 08:40:37 lb-a1s-hcpp-01 err sshd[3301]: pam_radius_auth: RADIUS server 147.204.66.88 failed to respond
Aug 17 08:40:40 lb-a1s-hcpp-01 err sshd[3301]: pam_radius_auth: RADIUS server 147.204.66.88 failed to respond
Aug 17 08:40:40 lb-a1s-hcpp-01 err sshd[3301]: pam_radius_auth: All RADIUS servers failed to respond.
Aug 17 08:40:40 lb-a1s-hcpp-01 warning sshd[3301]: pam_unix(sshd:auth): check pass; user unknown
Aug 17 08:40:40 lb-a1s-hcpp-01 notice sshd[3301]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=147.204.66.17
Aug 17 08:40:42 lb-a1s-hcpp-01 err sshd[3298]: error: PAM: Authentication failure for Cxxxxxxxx(USER) from 147.204.66.17
Aug 17 08:42:24 lb-a1s-hcpp-01 warning sshd[3302]: pam_unix(sshd:auth): check pass; user unknown
Aug 17 08:42:24 lb-a1s-hcpp-01 notice sshd[3302]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=147.204.66.17
Aug 17 08:42:26 lb-a1s-hcpp-01 err sshd[3302]: error: ssh_msg_send: write
Hope to get some input here and find the possible cause of this
3 Accepted Solutions
Please contact me directly and I can assist [email protected].
If you get it working, I would like to know why it wasn't working with the setup I posted. I have used that in the past with no issues.
we finally found out the issue. It was an ACL on an outbound switch that was blocking the UDP communication between the ISE and the device.
The communication issue was detected during a troubleshooting session with Hosuk.
Thanks in this part for the great support.
7 Replies 7
paul
Level 11
Level 11
I looked at my notes from a few years ago and all I had to do was set the F5-LTM-User-Info-1 value to the role I wanted in F5 and made sure the role had terminal access.  My read-only role had no terminal access set.
that has been set already. The F5 is working proper towards and ACS system which runs TACACS and RADIUS. We are trying to check the ISE as the ACS is end of life.
However, we tried today to authenticate an Aruba Wireless Controler, and there again. The same result. We are not getting a SSH prompt. We used the same Aruba attributes as the RADIUS system that is in place.
My assumption is still that the attributes are not communicated right to the devices and back.
Sure I will post all outcome and the solution
Hey,
I will send you today later an email so that we can discuss the issue further
