DNAC, ISE integration design help
M_alamin
Frequent Visitor
Frequent Visitor
we had situation where two nodes PAN,MNT must be installed on the cloud and two nodes PSN must be installed on prem, catalyst center (DNAC) installed on prem as well and we want to make integration with DNAC and ISE, question where we should enable pxgrid should we enable it on the cloud along with PAN, MNT only or along with PSN on prem only or enable it on all the nodes?
also we want to have wildcard certificate for PAN, EAP, Portal but as per my understanding its not allowed for pxgrid can i use internal PKI for pxgrid and if there any reference for pxgrid certificate creation since certificate should include both servcer and client ?
thanks
Mark Elsen
          - FYI : https://community.cisco.com/t5/networking-knowledge-base/how-to-cisco-dna-center-ise-integration/ta-p/3896410
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
