Dot1x problem
vishwancc
Level 6
Level 6
HELLO ALL:
We are having some problem with Dot1x.When users connect to Dot1x authentication port, users laptops are not getting authenticated with the server.I am attaching the debug output and running config .
smahbub
Level 11
Level 11
On interface FastEthernet0/7 Your reauthentication time is set to 7200 seconds which is by default is 3600 seconds.which means that reauthentication will happen every 7200 sec.Your quite mode timing is 5 sec and default is 30 sec.Try using the the default settings for reauth,retransmission and quiet mode timers and check for the issue.Also check for the Dot1x configuration.
refer the following url for the configuration guide:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00805e7a18.shtml
michael.leblanc
Level 9
Level 9
Add the following to your configuration:
aaa authorization network default group ias-servers
