Guest Wifi portal redirection flow
omerfaruk
I would like to create CWA guest SSID with ISE and WLC 9800. When a client connect to the SSID, it must be redirected to guest portal automatically, which is done in my environment.
- Connect to SSID, then redirect to guest portal automatically. (bypass is disabled)
Since I send the credentials to the clients via email, when they complete their registration, they must be able to leave guest portal and go to their email box. So, they must have an internet access. However, this internet access must be limited like 10 min. ---- (I tried to create ACL with deny 80, 443, then automatic redirect wouldn't work. When i created ACL with permit 80, 443, then clients wouldn't have internet access to check their emails.)
The client who received the credential from his email should return to the portal and log in.
How can i setup this flow? Would it be possible if i can do the following:
When the client connects, it will go to the portal with automatic redirection and register. Here, if ISE can put a sign or a flag for the radius request and 120 seconds later, the session timeout occurs. Since there is a termination-action = radius-request, if I can add the flags to the condition in the next request and redirect them to the same portal, they can log in with the credential they received.
15 Replies 15
omerfaruk
Thank you Aref.
Thomas, it was an educational video with good information, thank you for your effort!
When I create custom attribute, ISE needs to be populated it. Which is I don't need. I want only use an attribute which is already in Context Visibility > Endpoints > Attributes --> Portal.Name. Unfortunately, i am not able to add it to authorization policy. There should be, but i couldn't find. Is there any suggestion?
If I create a custom attribute and dynamically assign the portal.name value to this attribute, it will also reflect the name.
