How do I require client and machine Cert when using EAP-TLS on wireless?
paulle
I have the same policy in ISE being used for both wired and wireless authorization. In the wired auths I see both user and computer certificates but on the wireless side I only ever see computer certs being used. How do I change this behavior so that it matches the wired ?
Colby LeMaire
If the computers are only sending computer certificates on Wireless, that is a supplicant configuration issue.  You can create a Wireless GPO to push out the correct supplicant settings.  If using the built-in Microsoft supplicant, there is an option to do "Machine or User Authentication".  It is probably configured to do "Machine Authentication Only".
Colby LeMaire
hslai
Like Colby.LeMaire said, this depends on the supplicants. Even with Windows native supplicants, the auth mode is configured for individual wireless networks and wired connections.
