How to configure ACS 5.2 and Checkoint for firewall admin using TACACS
Marlon Malinao
Can somebody show how to configure ACS 5.2 for device administration of Checkpoint firewalls and security management servers?
thanks
thomas1337
I have created a "Authorization Profile" with a new "Shell Profile" policy.
In the policy i manualy entered this attributes:
Nokia-IPSO-SuperUser-Access=1
Nokia-IPSO-User-Role=adminRole
"adminRole" is a Checkpoint default role. You can create your own role and change these in your Shell Profile if needed.
The attribute are set to mandatory for this Shell Profile.
Hi Thomas,
Thanks for the reply,  this is for firewall gateway running IPSO, but how about the Security management server for checkpoint?
regards,
Marlon
Hi Marlon,
we use TACACS only to authenticate user against our Security Management Server, but for authorization there is a local user configured which refers to the TACACS user.
If you use Provider-1, look at page 54.
http://dl3.checkpoint.com/paid/53/CheckPoint_R65_Provider1_AdminGuide.pdf?HashKey=1344278626_b260a4b6b3969325ae6bb4fc12d66871&xtn=.pdf
In Cisco ACS, you configure an "Authorization Profile" and add only the Shell Profile "Permit Access"
Thomas
Hi Thomas,
Thanks for the reply, but i dont have enough privilege to access the link. will u able to share it?
