How to limit max sessions per users and per group in Cisco ACS when using LDAP?
slizarraga
I am using an ACS that uses an external identity store which is an AD server, I have configured to use LDAP.
I want to limit the max sessions per user and per group, but the limit only works on the Identity Groups, and non of my users are in Identity groups.  I thought I had 2 options:
 - Limit in my external identity store (it seems not possible)
 - Associate my LDAP groups to my Identity group
How can I implement the 2nd option??
Thanks for your help!!
(I saw a forum note that ask pretty much the same, but the link does not show how to make this association).
I have an attach with more info.
Gagandeep Singh
You can map LDAP or AD groups to Group mapping option for internal group.
Under Access policy > Default Device Administration > Group Mapping.
Still session limitation is on internal users.
Gagan
PS: rate if it helps!!!!
