https fails on ACS 3.3 solution engine
mchockalingam
Level 4
Level 4
Hi All,
I installed a self-signed certificate on the ACS solution engine running 3.3(3). I enabled https access for admin access. I do not have any restrictions as far as connecting IP. But when I try to connect, IE says "page cannot be displayed". However, firefox gives me an error message saying "invalid message authentication code". Anyone has experienced this?
thanks,
5 Replies 5
darpotter
Level 10
Level 10
Did https work before you installed the cert? Im not totally convinced csadmin uses the installed cert for https. I think that is for authentication only.
I have another ACS box running 3.2(3). I installed s self-signed cert and enabled https. Now when I access the box for admin access, it redirects http to https and works fine.
I am trying exactly the same thing on this box running 3.3(3). In this box, I installed the cert for 2 reasons, one for admin access and the other for PEAP. Neither one works. But certificate is installed and status says OK.
Hi Meena,
Did you find the Problem why https did not work?
I also have this Problem now, but I have several other ACS Servers where https works fine.
Peter
I had to replace the box with another one.
Since I closed an existing session after turning on https without checking, I could not get to manage the box. Reimaging did not help either.
Thanks for the Answer. I have the Problem on a Win2003 Server and so I am able to change the REG Key for https to get the Sessions back without https - But we need https here. I'll try to also set up a new box.
Peter
