Https redirection issue for Wireless Guest CWA - ISE 1.3
deepuvarghese1
Our Setup is
ISE 1.3 (Patch level 2) running on ACS 1121
2 nodes clustered with Admin, monitoring, policy service enabled ( Primary and Secondary ).
Configured SSID Guest for Centralized web authentication with ISE.
We have issues in web redirection with chrome . It is not redirecting to the ISE page but rather showing " Page cannot be displayed".
By default chrome is pointing to https. For example if we type https://google.com it is not redirecting to ISE page. But when I specify the same as http://google.com it works.
There is no issue with IE, Firefox as it is redirecting to ISE page with default https and i can see it is hitting our rule.
Please advice.
8 Replies 8
nspasov
Can you post a screenshot of your redirection ACL
Thank you for rating helpful posts!
Hi Neno,
Please find the attached ACL for CWA. The IP's mentioned in ACL are ISE primary and secondary.
Hmm, things look correct. Have you tried to clear the cache/cookies in chrome and then try again.
We have tried in many PC's with chrome but the result is same even after clearing the cache/cookies. Other browsers are working fine. Please suggest.
Yeah, I updated my chrome browser and now facing the same issue. I am guessing something changed within the dynamics of chrome that broke this. Are you by any chance using a self-signed certificate? I am having the feeling that it has something to do with untrusted certificates.
One of the PC Chrome version that we tested is with 40+ .
Page is not prompting for any certificate error while trying to load the page rather showing "page cannot be displayed". I will cross check what is the settings of their current certificate. I can try using a self signed cert if needed.
Hi Neno
They are using a third party certificate (digi cert) for client auth. They have confirmed even if they use a self-signed-cert the result is same.
So basically none of the https page is not loading. If we manually browse some https site from Firefox, IE the result is same showing " page cannot be displayed".
Redirection to https is the problem which i have never faced with my other customer. This is the upgraded version of ISE from 1.2 to 1.3.
paulnus001
Community Member
I did a +1 on this issue as well. We have instructed users to use other browsers for authentication against the wireless.
