Identity services engine Active directory issue
vicnetnoc
Frequent Visitor
Frequent Visitor
Hi Folks
We have two ISE instances running in a virtual machine environment on a Cisco UCS . Both ISE’s are running version 1.1.4 and have been patched to the latest engine patch for that version (patch 11).   The primary is setup to be the administration primary and the monitoring secondary and the secondary ISE  is setup as the administration secondary and the monitoring primary.
The Cisco UCS is connected to a pair of Nexus 5548 switches and they are connected to our core switches both Cisco 6500’s.
At the moment both ISE's can connect to Active Directory (test connection) but only the secondary can join. The error message I am getting on the priimary is:
Cannot open file /var/centrifydc/previous/kset.domain: No such file or directory
 due to unexpected configuration or network error.
Please try the --verbose option or run  adinfo --diag  to diagnose the problem.
Join to domain  staff.local , zone  null  failed.
Has anyone seen this error  before? I have compared the configs of the two instances and found no differences in configuration. One major difference I did find was that the primary is running Red Hat and the secondary is running Ubuntu.
Leo Laohoo
Duplicate post.
Go HERE.
