ip access-group not work between running Ath
Hi All
I found the acl not work before my device during running auth
below is the ACL
interface command
AAA command
Would you have any suggest for me?
Thanks!
Depending on the switch and version a "show ip access-list interface gig1/0/5" could shouw you the actually applied ACL. Looking at the config is not a valid check here.
And have you tried if there is really something different in place? Based on the shown output I would assume it works as expected.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Thank for your reply!
when the interface running auth to show ip access-list interface gig1/0/5.
I can't found any ACL is running.
on then other hand, when auth is work, it can successful the download ISE's DaCL  to interface and work.
Would you have any suggest to ip access-group was failed?
Thank for your help
