ISE 2.4 P4: Problems with EAP-MD5 authentication
Nadav
Level 11
Level 11
Hi everyone,
EAP-MD5 is supported only with internal database, so I made a local user identity group with a single user. That user is a shadow user that external authenticates with my external identity source (Active Directory).
So:  MyUser (External) --- > MyUserGroup
Here are some issues I've seen:
1) When authenticating with EAP-MD5, if I disable the user in AD the authentication still works.
2) When authenticating with EAP-MD5, even if I were to block all communications between PSN and AD authentication still works.
My policy set for EAP-MD5:
1) Allow protocol EAP-MD5
2) Authenticate from "Internal Users"
3) Authorize InternalUser.IdentityGroup EQUALS User Identity Groups: MyUserGroup
Any ideas why it's not performing proper checks with AD?
Thanks!
Timothy Abbott
What does your default authentication rule look like for the policy set and how is it configured?
-Tim
It's DenyAccess. Either it passes the EAP-MD5 rule, or is dropped
EAP-MD5 authentication is supported for internal database only (according to the documentation), but I assumed the user account associated with EAP-MD5 can be configured locally but get its password externally.
Apparently this doesn't work well, since I changed the password in AD for the user and yet it still authenticates correctly. Same goes for disabling the user in AD. However, if I make the user internal (don't check the External checkbox) then password verification and disable checks work fine.
From the looks of things this means I need to manage all EAP-MD5 users locally on ISE, and I can't use AD to manage their passwords.
Is this correct?
Any ideas?
