ISE 3.2 Integration with OpenLDAP Linux Shcema Problem
Hi All,
Anyone ever integrate the ISE with Open LDAP? I just little confuse with the Schema that I must input on 'LDAP Identity Source' menu.
With these configuration, I can retrieve groups from my LDAP, but the user on LDAP can't be retrieve from ISE. I tested it with Admin Access, which is the Admin Access of ISE I've forward to LDAP Server, and it still say wrong username/password on login prompt.
Anybody got the same problem with me?
Arne Bier
Hi @Rizaldo Frendy Kurniawan
I was also struggling when I tried to integrate ISE with Windows Active Directory using LDAP. I had to modify the Subject Name Attribute to use sAMAccountName.
How did I figure this out?  I used an LDAP explorer tool - there are many - e.g. LDAPSort LDAP Browser. I looked up my user account, then sorted the attribute VALUES list, looking for any attributes that contained the USERNAME I want to see in ISE. And there was only one attribute.
Arne Bier
