ISE auth assgin vlan problem, wireless problem, user problem and lan control problem
  1. Assign Gest Vlan successful but too long, below have some information for this problem1.PNG2.PNG3.PNG
  4. Using web-auth for Lan control but it can't transfer to login portal
ISETEST#sh authentication sessions interface g1/0/5
            Interface:  GigabitEthernet1/0/5
          MAC Address:  f0de.f1eb.4142
           IP Address:  192.168.3.54
            User-Name:  F0-DE-F1-EB-41-42
               Status:  Authz Success
               Domain:  DATA
       Oper host mode:  multi-auth
     Oper control dir:  both
        Authorized By:  Authentication Server
          Vlan Policy:  N/A
              ACS ACL:  xACSACLx-IP-Central_WEB_Auth-59f8469d
     URL Redirect ACL:  WEB-REDIRECT
         URL Redirect:  https://ciscoise.netcraft.com.mo:8443/portal/gateway?sessionId=C0A802F40000003C34CF384E&portal=4ba457d0-e371-11e6-92ce-005056873bd0&action=cwa&token=61c9177d0a2baa85346efd8057504f4c
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  C0A802F40000003C34CF384E
      Acct Session ID:  0x0000009A
               Handle:  0x2A00003D
Runnable methods list:
       Method   State
       dot1x    Failed over
       mab      Authc Success
anyone can me some suggest for these problem.
Arne Bier
The dynamic authorization failed when user logged into portal.  When user successfully logs into portal, then the ISE PSN will send a CoA (Change of Authorization) Radius packet to the NAS (i.e. your switch).  I suspect that your switch is not configured to
  • receive CoA on UDP/1700 (1700 is the Cisco default, but check your NAS to be sure)
  • shared secret has to match with what you have configured in ISE for that Radius device
  • Configure the switch to allow ISE IP address(es) to send CoA to it.  CoA is always initiated by the AAA server, and the NAS is the receiver in this case.
my aaa command :
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa server radius dynamic-author
client
192.168.2.205
 server-key cisco
ip device tracking
dot1x system-auth-control
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server host
192.168.2.205
 auth-port 1812 acct-port 1813
radius-server key cisco
radius-server vsa send accounting
radius-server vsa send authentication
and  I set below command, too
Device> enable
Device# configure terminal
aaa new-model
 client 192.168.2.205
 server-key cisco
port 1700
 auth-type all
ignore session-key
 ignore server-key
 end
but the result also is this error, cloud you give me some suggest?
ok.  I don't have wired switches in my deployment but I am able to get aaa debugs on my Cisco wireless controllers.  I find this is an excellent place to see whether ISE is sending you a CoA, and to see how the NAS responds to it.  If you have a deployment involving load balancers, firewalls and NAT/SNAT, then analysing the IP header of those CoA's can give you a clue.  On Cisco WLC the commands are  "debug aaa event enable"  and "debug aaa packet enable".  IOS will have some equivalent commands.
If you don't see the CoA in your switch debugs, then run a TCPdump on the ISE PSN that you suspect should be sending the CoA and see what's going on.  Analyse the .pcap in Wireshark.
I can't found  any about radiusCoASupportTransportThread: this type message when I enter command "debug aaa all enable"in the WLC. and I can found just like radius auth or radius accounting these type message in WLC.
