ISe Certificate problem
antero
Level 3
Level 3
i'm installing ISe with certificates, and get a problem when trying to install the certificate.
followyng cisco steps from the book, when do  "BIND CA Certificate" to EAP appears a message (as attached) saying that "there is no matching CSR to bind this certificate", when  try to management interface only appear an error that "management Certificate must contain teh HOST FQDN in CN component of subjetct field".
I configured the CN correctly as Document said.
Step 3 Create a certificate signing request (CSR)
a. Go to Administration > System > Certificates > Local Certificates, and click
Add
b. Generate a certificate signing request
Attribute Value
Certificate Subject CN=ise-1.demo.local
Key Length 4096
thanks
Antero
7 Replies 7
Steve Dussault
Frequent Visitor
Frequent Visitor
Did you ever resolve this?  I am getting the same message.
aman.diwakar
Level 3
Level 3
Im seeing the same problem in ISE
Are you using a microsoft CA server? If so are you copying and pasting the output of the CSR using RDP over to the CA? I hit the same issue before and as a workaround i ftp'd the csr file to the CA and copied and pasted it there and generated the cert. (I had to do this since I run a macbook and I can hit the CA page using Mozilla).
In my case I found the issue - the name of the ISE in CLI did not match exactly the name in the CSR.  The CSR must match the name of ISE host configured in the CLI.
Same with me, the name is actually case sensitive when creating the CSR.
Ravi Singh
Level 11
Level 11
I also stuck with same issue and later on found that there is problem with ise name in CSR it was not exactly match with ISE. I would suggest you to check the same.
bikespace
Level 4
Level 4
I don't know if its still valid, but there was also a recommendation that the server name should always be lower case. Just thought I'd add that. I'm still sticking to it just in case.
