ISE Hotspot / Captive Web Portal with HTTP (not HTTPS)?
Toivo Voll
Level 3
Level 3
We're setting up an ISE PoC for a hotspot (guests get redirected to an AUP page, and have to click "accept") and was wondering whether HTTPS (and certs, cert chains and all that stuff) is really necessary for this.
Perhaps I'm missing something obvious, but since there's no actual information (passwords, emails, names) being transferred, what's the need for HTTPS? Is there any way to allow plain old HTTP to the portal?
Antonio Torres
Right now this is not possible. ISE is a  security appliance  and HTTP support for Portal flows isn't even on the roadmap.
But that's actually a  good point. I can see some room for an enhancement request to have the ability to disable HTTPS on HotSpots flows if there is no access code enabled(optional)  since there are no credentials to protect during this stage.
5 Replies 5
Antonio Torres
Thanks for the response.
That's our use case; we only need users to agree to an AUP. There's just the "accept" button, no email field, no pin or anything else.
The challenge is that the clients are in private IP space but rely on public DNS, so as far as I can tell either we have to expose the ISE portal interface to the Internet, publish a public DNS record pointing at RFC1918 space or we can't have a valid cert for the guest portal. (Or we have to re-engineer guest DNS to allow for split views, but that's a different group and involves buying things.)
If you go with exposing ISE  you may select a dedicated interface for the HotSpot portal and even modify the port we'll be listening on  to avoid exposing other flows and management access as well.
We have it on a separate interface currently, but I'm still looking for documentation on how to, or whether it's possible to restrict it to guest portal flows only / ACL it within the ISE.
I can see that from the Linux side  but from ISE application side there is no way you can restrict this based on the interface you're hitting.
