ISE Problem with Conditions Studio
Amen
Level 5
Level 5
problems with editing my Policy sets as the conditions Studio doesn’t load at all.
It keeps trying to fetch data from the server…… but doesn’t load further.
See also Screenshot , any recommendations
2 Accepted Solutions
I tried Everything, I also opened a TAC, and they are still investigating, it is taking a long time, not sure why 🙂 but will inform you of the solution as soon as I receive it
11 Replies 11
Hi @Amen ,
 what is your ISE version and patch?
Note: worth the shot to try a different browser.
Charlie Moreton
Is it a VM?  What are the CPU, RAM, and HDD Resources dedicated to it?
Amen
Level 5
Level 5
Version: 3.0.0.458 Patch 4 Platform: SNS-3615-K9 , not a VM ,
a couple of weeks ago I had an issue with the ISE disk and TAC had to modify the database to fix the issue, I am not sure if I have to call TAC again, or if there is some workaround that can be done for now.
Hi @Amen ,
 I didn't find anything on ISE 3.0 Release Notes - Patch 5 Resolved Caveats that could solve your issue on 3.0 P4.
 If you already try a different browser without success, please open a TAC case.
Hi @Amen ,
 how many Nodes do you have?
 Open your ISE via Chrome > select More Tools > Developer Tools and open the Conditions Studio, for ex.:
Are you able to verify info on the right side (red square)? Could you PrtScr ?
See the screenshot, please :-
Hi @Amen ,
 interesting ... although your Conditions Studios is blank there are lot of Status = 200 OK, in other words, you are receiving the data (for ex.: POLICYSET), if you click the Name you are able to check the detail info:
Are you able to create a LAB in a VM with ISE 3.0 P4, restore a Config BK and test the Conditions Studios again ?
Hope this helps !!!
Could you solve the problem? We have the same failure.
Call TAC.
RUEDIGER SCHNEIDER
Community Member
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo02275
"Refresh Database Statistics" and "Reload" solved our problem ...
