ISE using Certificates for WLAN authentication
gugonza2
Hi Team,
I´m checking the configuration steps for ISE deployment using external CA for WLAN clients authentication.
I have a WLC configured with one SSID and using ISE as AAA system.
Also I have an external CA and my WLAN clients have Certificates provisioned by this CA using MDM services.
Now I would like to configure ISE to use it for authenticate the WLAN clients with Certificates.
Is there any guide or example of this configuration ?
Any documentation to understand the step-by-step configuration ?
Thanks in advance.
Hi @gugonza2 ,
Please refer Understand and configure EAP-TLS using WLC and ISE
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Hi @gugonza2 ,
Arne Bier
And if you find it easier to watch a video, then I highly recommend the www.labminutes.com - this guy covers every aspect of ISE in a nice step by step fashion.
