ISE2.4 : backup : failure using GUI and CLI stuck at 45%
Barracuda87
Hi all,
i have a problem on a BK ISE. BK stuck at 45% via CLI and GUI:
XXX/admin# backup  ISE-CONFIG repository XXXX ise-config encryption-key plain XXXXXXXX
% Internal CA Store is not included in this backup. It is recommended to export it using "application configure ise" CLI command
% Creating backup with timestamped filename: ...........................................
% backup in progress: Starting Backup...10% completed
% backup in progress: Validating ISE Node Role...15% completed
% backup in progress: Backing up ISE Configuration Data...20% completed
% backup in progress: Backing up ISE Indexing Engine Data...45% completed
Timothy Abbott
If the issue persists, please reach out to the TAC.
-Tim
Timothy Abbott
-Tim
Hi Tim,
can't I check the reason from the logs?
thx
Anto
Did anyone find a resolution to this other that call TAC? Seems to be a common issue if you search other message boards. Same with the disk full issues with ISE but never a "real" resolution is offered.
You can try to cancel the backup via the CLI prior to calling TAC. On the primary admin node enter the following;
use option "[24]Force Backup Cancellation"
Disk full issues are certainly a TAC case, you still since you need root access to fix it.
