MAB problem on Catalyst 2960 Switch
ngtransge
Level 4
Level 4
I have problem with 801.X MAB authentication on Cisco WS-C2960-24PC-L switches.  Hire is port configuration on Cat 2960 switch
interface FastEthernet0/2
switchport access vlan 31
 switchport mode access
 authentication order mab
 authentication port-control auto
 authentication violation restrict
 mab
 dot1x pae authenticator
 storm-control broadcast level 40.00
 storm-control action shutdown
 spanning-tree portfast
 spanning-tree bpduguard enable
The problem is that as soon, as I turn on authentification on port, MAB starts running, and is unable to detect MAC address on port, also when I check port with show mac add command I am unable to see MAC address. But MAC address really exist on that port. When I turn of authentication on port, with show mac add command I can see that MAC address exist on port.
Hire is debug from Cisco switch:
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) dot1x_pm_mda_port_link_linkcomingup: voice VLAN 4096, data VLAN 31
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Enabling dot1x in switch shim
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2)  set host access to ask on FastEthernet0/2
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2)  host access set to 1 on FastEthernet0/2
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Link UP
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Assigned AAA ID 0x0000001D
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Retrieved Accounting Session ID 0x0000001D
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Allocated new Auth Manager context (handle 0x0500001A)
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Client 0000.0000.0000, Initialising Method mab state to 'Not run'
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Adding method mab to runnable list for Auth Mgr context 0x
*Mar  1 00:08:18.333: AUTH-EVENT: auth_mgr_idc_add_record: Recv audit_sid=C0A80E4A0000001A00079A9D
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Sending START to mab (handle 0x0500001A)
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Received handle 0x17000013 from method
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Client 0000.0000.0000, Context changing state from 'Idle' to 'Running'
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) Client 0000.0000.0000, Method mab changing state from 'Not run' to 'Running'
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) dot1x_mab_get_mac: We are going to start listening for macs on port FastEthernet0/8
*Mar  1 00:08:18.333: AUTH-EVENT (Fa0/2) dot1x_mab_set_mac_sent: Listening for MAC on port FastEthernet0/2
*Mar  1 00:08:18.342: AUTH-EVENT (Fa0/2) dot1x_is_mab_interested_in_mac: Still waiting for a MAC on port FastEthernet0/2
*Mar  1 00:08:18.342: AUTH-EVENT (Fa0/2) dot1x_is_mab_interested_in_mac: Still waiting for a MAC on port FastEthernet0/82
*Mar  1 00:08:18.342: AUTH-EVENT (Fa0/2) Host access set to ask on unauthorized port since feature
*Mar  1 00:08:18.342: AUTH-EVENT (Fa0/2)  host access set to 1 on FastEthernet0/2
*Mar  1 00:08:18.635: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state to up
#show authentication sessions interface f0/2
Interface:  FastEthernet0/2
MAC Address:  Unknown
IP Address:  Unknown
Status:  Running
Domain:  UNKNOWN
Oper host mode:  single-host
Oper control dir:  both
Session timeout:  N/A
Idle timeout:  N/A
Common Session ID:  C0A80E4A0000001A00079A9D
Acct Session ID:  0x0000001D
Handle:  0x0500001A
Runnable methods list:
Method   State
mab      Running
I have checked number of IOS like 12.2.55-SE9, 15.0.2.-SE7, and 15.0.2.-SE6. But same problem exists
Can you please help me with that problem?
mohanak
CSCtl42740
Symptom:
Switch may go in high CPU after losing connectivity with AAA server, with MAB and critical vlan enabled.
The logs are filled with these messages:
AUTH-EVENT (Gi0/15) Received clear security violation
AUTH-EVENT (Gi0/15) dot1x_is_mab_interested_in_mac: Still waiting for a MAC on port GigabitEthernet0/15
Update the IOS to
12.2(58)SE
12.2(55)SE3
15.0(4.1)SID
Hello mohanak,
Do you think, that my problem is because of that bug ? Because bug reference different hardware platform and IOS.
nspasov
What type of device are you trying to authenticate on the port? Also, how long do you wait before you give up?
Thank you for rating helpful posts!
