Machine dot1x authentication to work with both on prem and Azure AD
raymondmf
Has anyone been able to integrate both Azure AD and on prem AD to authenticate devices?
Greg Gibbs
The only current method for authenticating 802.1x against AzureAD requires using ISE 3.0 and ROPC.
See the Configure ISE 3.0 REST ID with Azure Active Directory TechNote for more information.
thomas
Unclear what your exact scenario and problem is.
Can you integrate on-premise AD and Azure AD with ISE? Yes.
Can you do machine authentication with ISE to on-premise AD? Yes.
Can you do 802.1X machine authentication with ISE directly to Azure AD? No.
But this should not be an issue because if you're doing 802.1X with a wired or wireless access edge at L2 (even with a telecommuter/OEAP in an employee's home) you could still authenticate to ISE in your data center with traditional on-premise AD.
See :
Compare Active Directory to Azure Active Directory
Azure AD device identity documentation
How to: Plan your Azure AD join implementation :
