Max Sessions for user and machine in external identity groups
piotrPaszk
I am facing a challenge how to limit a number of session for users and machines. I do not see that option for the version of ise 2.4 I am using at the moment.
Is this only posible to limit users only. I am using eap-tls for machine autorization and I am wondering how to limit that ?
Is this something which comming on the road map ? If not, Is there any work around ?
Br
Piotr
2 Accepted Solutions
Francesco Molino
Follow this link:
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/admin_guide/b_ise_admin_guide_23/b_ise_admin_guide_23_chapter_01110.html#id_30990
It shows how to limit the concurrent session per user or per group.
Per user is based per psn whereas per group is max session for a user on all PSNs in the group.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Nope today you can't do it based on AD Group. An enhancement is opened but still nothing:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd22392
The user limit will be per PSN only.
Francesco
Francesco Molino
Follow this link:
Francesco
Hi Francesco :)
Thank you for the answer. But I just wonder
1. if it is possible to use those limits with external identity groups ? I did not see any group I have defined which come from AD on that list.
2. If user limit is per SSID og PSN or just PSN ?
Br Piotr
Francesco
