Need help with AAA configuration
jwheat
Community Member
I am trying to configure AAA on my network devices. I am using TACACS+ with an ACS (3.2) server. I have setup two user groups in the ACS server, one with enable priviledges and one without. I am able to get the AAA configuration to work when telnetting into the devices. However, when logging into the console port, the user group with enable priviledges do not go directly into enable mode as the telnetted users do. How to fix this?
Vivek Santuka
You will need to use the following command :-
aaa authorization console
This command will not show up on the help.
Vivek
Vivek Santuka
Vivek
