Need help with ISE posture
MedTek26
Frequent Visitor
Frequent Visitor
Dear Cisco community,
After setting up the temporal agent and configuring the different authorization profiles and Policy Sets, I proceed to test it on a client.
Initially, everything functions as expected, but an issue arises after the compliance check phase.
As you can see in the screenshot above : regardless of whether the device is compliant or not, Cisco ISE won't progress beyond the authorization policy stage. Ideally, it should apply the appropriate authorization profile based on the device's compliance status. Resulting in sending a Blank CoA without any attributes other than ACCESS ACCEPT.
Authentication Policy :
Authorization Policy :
Client PoV :
Under the live session the posture status is blank :
Under the contexte visibility :
Report :
The client is a VM and dosent have the Windows firewall activated and is up to date.
I am using the latest Cisco ISE-3.2.0.542a-virtual-SNS3615-SNS3655-300
If anyone already had experienced that or have hints to share with me, that could help me a lot and would be greatly appreciated.
Thank you !
Mehdi
hslai
@MedTek26 The identity column showed as INVALID so that means the auth was not successful so it seems MAB is not configured properly for your Alcatel device.
