Need posture configuration guide for Aruba on ISE
songl
Hi all
Need posture configuration guide for Aruba on ISE, do you have it?
BR
Songl
Craig Hyps
Level 10
Level 10
Suggest review
ISE Design & Integration Guides
ISE Third-Party NAD Profiles and Configs
Although not required to work with Aruba, ISE 2.2 adds support for Posture without URL redirection, so not hard requirement to configure the redirection on the Aruba WLC itself.  ISE 2.2 documentation discusses Posture services without NAD redirect.
Craig
Craig Hyps
Level 10
Level 10
Suggest review
Craig
