Order of installation during patch upgrade in Small ACS deployment
iciar_acfe
I am upgrading 2 ACS appliances from 4.1.4.13 to 4.1.4.13 patch 20. They are configured as primary and backup. In the documentation I don't see any restriction on which should be the first machine to be upgraded. Should the backup one be the first to be upgraded, and therefore, the "new" primary?
Thanks a lot.
atif
Assuming all devices are pointing to the primary ACS IP, you should stop the replication, upgrade the backup, then upgrade the primary and then enable replication. Although I do not see any problem upgrading the primary first after replication has been stopped.
HTH,
Atif
atif
HTH,
Atif
Thanks a lot
