Password Management Problem
Hi all,
We are using ACS 5.2 to authenticate users from SSL VPN connection. Users can login fine by the username and password created on the ACS, the problem is when we enable the change password on next login check box, users will stop to login. I know this was a bug issue in ACS 4.0 series. Does this issue is not resolved on ACS 5.2?
Thank you
Mulu
Any Idea on this?
