Please help trouble shooting RADIUS
nguyenbinh
I could telnet in to my Cisco 2620 using RADIUS authentication
"telnet 192.168.4.10 2033" (provide username/pass)
and then type AT which My modem reply with OK.
I could also dial-in to the NAS with local user
But I could not dial-in using RADIUS user.
Please help me trouble shoot the problem.
I enclose the debug information and also the configuration I used.
Thank you,
Nguyen Nhat Binh
Username: test
Password:
Cisco2620>ena
Password:
Cisco2620#
Cisco2620#
Cisco2620#
Cisco2620#terminal monitor
Cisco2620#
02:28:00: %LINK-3-UPDOWN: Interface Async33, changed state to up
02:28:00: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
02:28:24: %LINK-5-CHANGED: Interface Async33, changed state to reset
02:28:29: %LINK-3-UPDOWN: Interface Async33, changed state to down
02:28:35: %LINK-3-UPDOWN: Interface Async33, changed state to up
02:28:35: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
02:28:46: %LINK-5-CHANGED: Interface Async33, changed state to reset
02:28:51: %LINK-3-UPDOWN: Interface Async33, changed state to down
02:29:15: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
02:29:15: %LINK-3-UPDOWN: Interface Async33, changed state to up
02:29:16: AAA: parse name=Async33 idb type=10 tty=33
02:29:16: AAA: name=Async33 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=33 c
hannel=0
02:29:16: AAA/MEMORY: create_user (0x80CD711C) user='test' ruser='' port='Async3
3' rem_addr='async' authen_type=CHAP service=PPP priv=1
02:29:16: AAA/AUTHEN/START (327574709): port='Async33' list='' action=LOGIN serv
ice=PPP
02:29:16: AAA/AUTHEN/START (327574709): using "default" list
02:29:16: AAA/AUTHEN (327574709): status = UNKNOWN
02:29:16: AAA/AUTHEN/START (327574709): Method=radius (radius)
02:29:16: RADIUS: ustruct sharecount=1
02:29:16: RADIUS: Initial Transmit Async33 id 89 192.168.4.141:1645, Access-Requ
est, len 75
02:29:16: Attribute 4 6 C0A8040A
02:29:16: Attribute 5 6 00000021
02:29:16: Attribute 61 6 00000000
02:29:16: Attribute 1 6 74657374
02:29:16: Attribute 3 19 27440611
02:29:16: Attribute 6 6 00000002
02:29:16: Attribute 7 6 00000001
02:29:16: RADIUS: Received from id 89 192.168.4.141:1645, Access-Accept, len 44
02:29:16: Attribute 27 6 0098967F
02:29:16: Attribute 28 6 0000000A
02:29:16: AAA/AUTHEN (327574709): status = PASS
02:29:16: As33 AAA/AUTHOR/LCP: Authorize LCP
02:29:16: As33 AAA/AUTHOR/LCP (1939832978): Port='Async33' list='' service=NET
02:29:16: AAA/AUTHOR/LCP: As33 (1939832978) user='test'
02:29:16: As33 AAA/AUTHOR/LCP (1939832978): send AV service=ppp
02:29:16: As33 AAA/AUTHOR/LCP (1939832978): send AV protocol=lcp
02:29:16: As33 AAA/AUTHOR/LCP (1939832978): found list "default"
02:29:16: As33 AAA/AUTHOR/LCP (1939832978): Method=radius (radius)
02:29:16: As33 AAA/AUTHOR (1939832978): Post authorization status = PASS_REPL
02:29:16: As33 AAA/AUTHOR/LCP: Processing AV service=ppp
02:29:16: As33 AAA/AUTHOR/LCP: Processing AV timeout=9999999
02:29:16: As33 AAA/AUTHOR/LCP: timeout failed
02:29:16: As33 AAA/AUTHOR/LCP: Denied
02:29:16: AAA/MEMORY: free_user (0x80CD711C) user='test' ruser='' port='Async33'
02:29:18: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
02:29:20: %LINK-5-CHANGED: Interface Async33, changed state to reset
02:29:25: %LINK-3-UPDOWN: Interface Async33, changed state to down
! Cisco2620.cfg - Cisco router configuration file
! Automatically created by Cisco ConfigMaker v2.6 Build 6
! Wednesday, December 31, 2003, 01:58:10 PM
! Hostname: Cisco2620
! Model: 2620
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname Cisco2620
enable password xxxxx
username dong password xxxx
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface FastEthernet 0/0
no shutdown
description connected to EthernetLAN
ip address 192.168.4.10 255.255.255.0
no keepalive
interface Async 33
no shutdown
description connected to Dial-inPCs(modem)
ip unnumbered FastEthernet 0/0
ip tcp header-compression passive
encapsulation ppp
async mode dedicated
! group-range 33 33
ppp authentication chap pap
no cdp enable
peer default ip address pool Cisco2620-Group-1
router rip
version 2
network 192.168.4.0
no auto-summary
ip local pool Cisco2620-Group-1 10.10.10.10 10.10.10.10
ip classless
no ip http server
snmp-server community public RO
no snmp-server location
no snmp-server contact
line console 0
exec-timeout 0 0
password a
login
line vty 0 4
password xxxx
login
line 33
exec
autoselect ppp
autoselect during-login
login local
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
aaa new-model
aaa authentication login default radius local
aaa authentication login no_radius enable
aaa authentication ppp default if-needed radius
aaa authorization network radius
aaa accounting exec start-stop radius
aaa accounting network start-stop radius
radius-server host 192.168.4.11 auth-port 1645 acct-port 1646
radius-server key ubtq
gfullage
This looks to be the problem:
You're doing authorization (not just authentication) on your dialup users, not sure if you really want that or not. If so, then you will have a session-timeout set in the Radius users profile, you can see the radius server replying with this:
which when decoded becomes:
02:29:16: Service-Type Framed
02:29:16: Framed-Protocol PPP
02:29:16: Session-Timeout 9999999
02:29:16: Idle-Timeout 10
I would say the NAS/router doesn't like the Session-Timeout being so high, try lowering it and see what happens.
Alternatively, if you don't really want to do authorization for your dialup users, then remove the line:
and the problem should also go away.
Thank you alot for your support, I resolved the problem. Actually, I do not need authorization.
Wish you all the best for a new year.
