Posturing with easy connect for 3rd party devices
Anjan Das
Hi Team,
We are no full support for passive authentication with easy connect, can we do posturing also without restricting to any 3rd party devices.
Customer don't want to use 802.1x authentications.
Please suggest.
Anjan
Craig Hyps
Level 10
Level 10
Posture is supported for most 3rd-party switches and we officially tested a number of vendors.  However, Easy Connect has not been validated with 3rd-party switches. I have not tested.  If it works, then should be good to go.  If not, then you will need to submit enhancement request through Cisco account team.  If not working, then may require some tweaking to CoA logic for 3rd-party devices that do not support reauth.  I would also look at CoA Push for 3rd-party switches that support it.
/Craig
ldanny
Please see compatibility guide.
Cisco Identity Services Engine Network Component Compatibility, Release 2.2 - Cisco
If not listed we cannot claim support however that does not mean it wont work . Best to test in your own lab enviorment.
Danny
Craig Hyps
Level 10
Level 10
/Craig
