Problem auth Tacacs+
networkIT_15
Frequent Visitor
Frequent Visitor
Hello
i have configure tacacs on switch cisco and cisco ise  my problem I can not access with user create on ise only with local user and no log display in ISE
i verife my shared key /address is ok
config  on Switch
aaa new-model
aaa group server tacacs+ ISE_TACACS
server name ISE
aaa authentication login default group ISE_TACACS local
aaa authorization exec default group ISE_TACACS local if-authenticated
aaa accounting exec default start-stop group ISE_TACACS
aaa session-id common
ip tacacs source-interface Vlan99
tacacs server ISE
address ipv4 *******
key 7 ********
Greg Gibbs
There is not enough information to provide much useful assistance. Do you have the VTY lines configured to use AAA?
I would suggest checking your setup against the ISE Device Administration Prescriptive Deployment Guide.
If you are still having issues, we would need more information to help. See How to Ask the Community for Help or contact TAC is the issue is urgent.
Greg Gibbs
