Problem authenticating Wireless users with peap
drombau14
Community Member
Good afternoon,
I am currently trying to authenticate wireless users using PEAP and an external RADIUS server. The problem is when I try to authenticate I get this error :
AAA/AUTHEN/PPP : Pick method list 'Permanent Local'
DOT11-7-AUTH_FAILED : Station ... Authentication failed
It shouldn't use local authentication, but the aaa server I configured.
I looked on the internet but didn't find a working solution.
Does anyone know why it is not working ?
Here is my running configuration :
Current configuration : 4276 bytes
! Last configuration change at 00:45:40 UTC Mon Mar 1 1993
! NVRAM config last updated at 16:38:23 UTC Thu Jul 24 2014
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$QVC3$dIVAarlXOo52rN3ceZm1k0
aaa new-model
aaa group server radius rad_eap
 server 192.168.2.2 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip routing
no ip cef
dot11 syslog
dot11 ssid test
   authentication open eap eap_list
   authentication key-management wpa version 2
   guest-mode
eap profile peap
 method peap
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid test
 antenna gain 0
 stbc
 beamform ofdm
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 dot1x pae authenticator
 bridge-group 1
interface BVI1
 ip address 192.168.3.10 255.255.255.0
 no ip route-cache
ip default-gateway IP
ip forward-protocol nd
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.2.2 auth-port 1812 acct-port 1813 key 7 140441081E501F0B7D
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
 transport input all
end
Thank you
nspasov
I haven't setup autonomous APs before but I think I might see the problem. You are defining an authentication list called "eap_methods" but you never call for it in your SSID settings. Instead there you call a list named "eap_list" In addition, I think you might be missing one more command. So perhaps try this:
dot11 ssid test
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
Hope this helps!
Thank you for rating helpful posts!
nspasov
dot11 ssid test
   guest-mode
Hope this helps!
Thank you so much, I had read this many times but I had not seen this error.
It now works perfectly 🙂
It happens to all of us 🙂 Glad I was able to help!
