Problem with http authorization
kuzmindanil
Community Member
Hello, have a problem with http authorization through AAA
I have tried this one
#aaa authentication login default group tacacs+ local
#ip http authentication aaa login-authentication default
and this
#aaa authentication login SUPERLIST group tacacs+ local
#ip http authentication aaa login-authentication SUPERLIST
But everytime when I try to login with CCP or on http/https router authorize me only with local user.
Maybe I don't understant how to work named list....
IOS Version 12.4(13r)T
Need help!
Calvin Ryver
Level 2
Level 2
It looks like you are logging in with just the basic prompt.
The config should look similar to
aaa authentication login default tacacs local
aaa authorization exec default tacacs       (This should put you in exec at priv 15 if the aaa server is set up correctly)
ip http server
you may want to run the following debugs on the router to see what is happening
debug tacacs
debug aaa authen
debug aaa author
what tacacs server are you using, see the doc at
http://www.cisco.com/en/US/customer/tech/tk59/technologies_configuration_example09186a0080178a51.shtml
