Problem with token card authentication
zroth
Level 3
Level 3
Hi everybody,
I have this problem.We have an access router CISCO 3640,IOS c3640-is56i-mz.121-6 for dial-up access and
CSACS access-server V 2.4.Users are using a token card authentication (Crypto Card).It works quite good.Encryption is not used.
Now we need to use 3des encryption,so we did IOS upgrade to IOS 12.2.15T9.After that the token
card access stopped to work - authentication failure.
The configuration is the same one.We stepped back to
the original IOS version and everything is O.K.
Has anybody an idea,what could go wrong ?
Zdenek
SBS Czechia
umedryk
Level 11
Level 11
Hi Zdenek,
User authentication fails if the client username has a domain delimiter character (eg., @) in it and if the domain name does not match the authentication group name)
