Problems witch acs 4.2 replication
jaouad laktami
Frequent Visitor
Frequent Visitor
i installed the primary and secondary server.
i see only one problem in the logs.
when i try to replicate
i get this :
cisco acs 01/04/2012 23:50:58 NTVMEM73 INFO Outbound replication cycle starting...01/04/2012 23:40:25 NTVMEM73 INFO Outbound replication cycle starting...01/04/2012 23:29:51 NTVMEM73 INFO Outbound replication cycle starting...01/04/2012 23:19:16 NTVMEM73 INFO
further no issue
can someone helps me
16 Replies 16
We are getting closer
Can you remove only Distribution Table from the Send options and try with the others enabled? Keep the "EAP-FAST master keys and policies" unchecked as well.
Hope this helps.
Regards.
i tried that
but it not working
replication is only working with:
user and group database
network configuration device tables
so how important are
the other things
