QR Code for Guest for attendance taking
lekrane
I am currently running on ISE v2.6.0.156 patch 2
Is there any script that i can use to generate a QR code that contain the guest's name and company?
This QR code will be emailed to the guest with the userid and password?
So you want them to scan the QR code to get the company name and other info? What are they going to do with that? @Arne Bier  mentioned a solution, you'd have to get a QR generator to do what you want. it really has nothing to do with ISE
All our commonly asked items are at http://cs.co/ise-guest please take a look, there is an example of other stuff with QR there
5 Replies 5
Arne Bier
Hi @lekrane
Try this free QR Code generator web page.
regards
Thanks but i am looking for a script that will auto generate the QR code in the auto send email when a sponsor register a guest
my question may not be clear.
The sponsor will register a guest in the sponsor page.
ISE will send an email to the guest and it shall contain a QR code that have the guest name and company detail.
The purpose is for attendance taking in the event.
Hi lekrane,
Did you manage to find a solution?
