RADIUS+MS-CHAP+IAS authentication problem
scolombo
We're configuring a Dial-in access authenticated by Microsoft 2003 IAS Server.
Here after the configuration :
aaa new-model
aaa authentication ppp dialins radius local
aaa authorization network default radius local
aaa accounting exec default start-stop radius
aaa accounting commands 15 default start-stop radius
aaa accounting network default start-stop radius
interface Serial2
physical-layer async
ip unnumbered Ethernet0
no ip directed-broadcast
ip nat outside
encapsulation ppp
autodetect encapsulation ppp
async default routing
async mode interactive
no cdp enable
ppp authentication ms-chap chap callin dialins
radius-server host 10.213.48.121 auth-port 1645 acct-port 1646
radius-server key xxxxxx
The authentication phase fails with the following errors :
*Mar 1 21:38:03: Se2 PPP: Phase is AUTHENTICATING, by this end
*Mar 1 21:38:03: Se2 CHAP: O CHALLENGE id 30 len 24 from "RADIUS-TEST"
*Mar 1 21:38:03: Se2 LCP: I IDENTIFY [Open] id 3 len 18 magic 0x53BC1EBF MSRASV 5.10
*Mar 1 21:38:03: Se2 LCP: I IDENTIFY [Open] id 4 len 23 magic 0x53BC1EBF MSRAS-1-TRINITY
*Mar 1 21:38:03: Se2 CHAP: I RESPONSE id 30 len 61 from "testras"
*Mar 1 21:38:03: AAA: parse name=Serial2 idb type=10 tty=2
*Mar 1 21:38:03: AAA: name=Serial2 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=2 channel=0
*Mar 1 21:38:03: AAA/AUTHEN: create_user (0xEC9B8) user='testras' ruser='' port='Serial2' rem_addr='async' authen_type=MSCHAP service=PPP priv=1
*Mar 1 21:38:03: AAA/AUTHEN/START (3977775049): port='Serial2' list='dialins' action=LOGIN service=PPP
*Mar 1 21:38:03: AAA/AUTHEN/START (3977775049): found list dialins
*Mar 1 21:38:03: AAA/AUTHEN/START (3977775049): Method=RADIUS
*Mar 1 21:38:03: RADIUS: ustruct sharecount=0
*Mar 1 21:38:03: RADIUS: Initial Transmit Serial2 id 63 10.213.48.121:1645, Access-Request, len 133
*Mar 1 21:38:03: Attribute 4 6 0AD52C0D
*Mar 1 21:38:03: Attribute 5 6 00000002
*Mar 1 21:38:03: Attribute 61 6 00000000
*Mar 1 21:38:03: Attribute 1 9 74657374
*Mar 1 21:38:03: Attribute 26 16 00001370B0A168A
*Mar 1 21:38:03: Attribute 26 58 0000013701341E01
*Mar 1 21:38:03: Attribute 6 6 00000002
*Mar 1 21:38:03: Attribute 7 6 00000001
*Mar 1 21:38:03: RADIUS: Received from id 63 10.213.48.121:1645, Access-Reject, len 42
*Mar 1 21:38:03: Attribute 26 22 0000013702101E45
*Mar 1 21:38:03: AAA/AUTHEN (3977775049): status = FAIL
*Mar 1 21:38:03: Se2 CHAP: Unable to validate Response. Username testras: Auth
entication failure
*Mar 1 21:38:03: Se2 CHAP: O FAILURE id 30 len 26 msg is "Authentication failur
e"
*Mar 1 21:38:03: Se2 PPP: Phase is TERMINATING
*Mar 1 21:38:03: Se2 LCP: O TERMREQ [Open] id 105 len 4
*Mar 1 21:38:03: AAA/AUTHEN: free_user (0xEC9B8) user='testras' ruser='' port='
*Mar 1 21:38:05: Se2 LCP: TIMEout: State TERMsent
Can anyone help me with this issue
Stefano COlombo
umedryk
Level 11
Level 11
Include on the ppp authentication ms-chap, and enable the same on the radius server.
