Replication Problem in ACS ver 4.2
cristian.munoz
Level 7
Level 7
Hi Guys
I have the following problem. In the ACS primary have an error: ACS `Secondary` has denied replication request. And the secondary have the message:  Inbound database replication from ACS ´Primary´ denied - shared secret mismatch.
They are working and suddenly stopped working.
Any idea?
TIA
Cristian
Tarik Admani
Are these appliances? Also did you experience any power failures? If you go look at the network devices let me know if the self entry resolves to its loopback address. If it does the fastest workaround is to console into the device and have dhcp set the ip address and let it restart and then go back and set the ip address statically again.
Here is the guide on how to configure this on the appliance -
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/cliap.html#wp1194461
here is the bug you are hitting -
CSCso36620            Bug Details
"Toggle nic" command changes AAA server ip address to "127.0.0.1" in GUI.
Symptom:
The ACS SE appliance IP address shows up as 127.0.0.1 on the ACS GUI.
Conditions:
This occurs after issuing the "toggle nic" command, or by unplugging the ACS SE appliance from the network.
Workaround:
The original IP address on the appliance can be restored with the "set ip" command
Tarik Admani
Dear Tarik
Thanks for you answer. Before to make the change in the ip address, I have delete the network configuration into web console in the primary? For change the IP address I must be do by console connection?
TIA
Cristian
