Replication problem
sachin
Level 5
Level 5
We are facing problem with the replication--
I cannot take backup from GUI but i can take backup with command prompt with CSutil utility. Log collected in CSAuth file is as follows--
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) reload reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAuth\CRCs from file C:\Program Files\CiscoSecure ACS v3.2\CSAuth\DbSyncScratch\CRCREG.RDF
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) Failed to copy directory C:\Program Files\CiscoSecure ACS v3.2\DCS to C:\Program Files\CiscoSecure ACS v3.2\CSAuth\DbSyncScratch\\DCS Reason 5
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\Device Command Set Types
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAuth\AgingPolicies
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot copy file C:\Program Files\CiscoSecure ACS v3.2\CSAuth\user.dat
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot copy file C:\Program Files\CiscoSecure ACS v3.2\CSauth\user.idx
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot copy file C:\Program Files\CiscoSecure ACS v3.2\CSauth\varsdb.mdb
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\Hosts
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\Network Device Groups
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\ProxyTable\Entries
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\Dictionaries\000
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAdmin\config
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAdmin\Administrators
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAdmin\Security
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAuth\Password Rules
AUTH 02/29/2004 11:49:32 E 0951 6404 Comms lib:CSBackupRestore(OUT) cannot save reg key SOFTWARE\Cisco\CiscoAAAv3.2\CSAuth\UserPasswordChange
AUTH 02/29/2004 11:49:32 E 1651 6404 DBReplicate(OUT) cannot backup sync aborted
what could be the problem ? Can anyone help me ?
m.chase
Community Member
When we upgraded from ACS 3.1 to 3.2, replication broke. There's a registry fix & patch for that. Basically replication took too long so the CSMon service thought ACS died and would reset the services thus breaking the replication in process. The registry fix allows you to set an interval for the CsMon checking to be long enough to allow replication to complete. Contact TAC, they can fill you in.
We have not upgraded ACS from 3.1 to 3.2, infact we have installed 3.2 version directly.
Problem solved.I formatted the system and reinstalled it. Replication and backup both are happening now.It was microsoft..not the cisco !!!!!
