SGT-IP enforcement on a Cisco switch with a device authenticated on an Aruba WLC
jpujol
Hi team,
Would anyone able to confirm / invalidate the possible trustsec integration between an Aruba WLC and a Cisco switch, if ISE publishes the SGT-IP mapping to the switch thru SXP ?
expected scenario :
- device gets authenticated on the Aruba WLC thru ISE (dot1x + cert or user credentials)
- Aruba WLC sends the device IP address to ISE via radius accounting
- ISE is able to enter the SGT-IP mapping in its local store
- ISE publishes the SGT-IP entry to Cisco switches via SXP
Have you ever seen this in action ?
Thanks for any feedback,
Rgds,
Jean-Francois
hslai
Affirmative.
ISE 2.0+ Support for SXP is there for a use case like you described.
