Sizing of SXP for switches
gvanbon
Where can we find what the sizing limits are regarding SGT-IP mappings and max number of SXP sessions for switch models ?
I am looking for cat6k with sup2t.
Is there some central place where we can find this for all Cisco switches ?
The Trustsec 6.5 System bulletin will provide the information on maximum SXP connections and IP-SGT bindings etc per switch model, link here.
Thanks!
Damien Miller
Keep in mind that the numbers in table 4 page 15 of the TrustSec system bulletin are best case scenario in a lab.  I have never been able to come close to reaching the max SXP connections stated while in production without encountering scaling issues.
It's really a balance that can be difficult to predict where total mappings, endpoint activity, and total sxp connections all factor. Try to avoid bidirectional SXP connections if at all possible, opting for a uni directional design.  ex. ISE as a speaker.  We are able to beef up ISE better than a router/switch for large multiconnection SXP processing.
