SSH problem
ashahnawaz
Community Member
Hi.
i have added an ACL to allow certian IPs to the managment Vlan.  Upon adding this ACL i can ssh to the device but get an access denied. upon removing the ACL works fine
here is the config- some sensitive details removed
interface Vlan200
description ***Management***
ip address 192.168.68.2 255.255.255.0
ip access-group ACL_MGMT_in in
ip default-gateway 192.168.68.1
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
ip access-list extended ACL_MGMT_in
10 permit ip host 192.168.150.100 any
20 permit ip host 192.168.150.101 any
30 permit ip host 192.168.150.102 any
40 permit ip host 192.168.150.103 any
50 permit ip host 192.168.150.104 any
60 permit ip host 192.168.150.105 any
70 permit ip host 192.168.152.20 any
80 permit ip 192.168.68.0 0.0.0.255 any
90 deny ip any any
control-plane
service-policy input system-cpp-policy
line con 0
stopbits 1
line vty 0 4
exec-timeout 60 0
privilege level 15
transport input all
line vty 5 15
exec-timeout 60 0
privilege level 15
transport input all
end
Use
Ip tacacs source-interface vlan200
8 Replies 8
Not sure on the exact issue, we apply the ACL to the VTY.
line vty 0 15
length 54
logging synchronous
exec-timeout 15
transport input ssh
access-class 10 in vrf-also
Hi @ashahnawaz
 ACL applied to Interface vlan does not block traffic send to the device CPU like SSH (Management traffic).  You need to apply the ACL on the line vty
line vty 0 4
 access-class  ACL_MGMT_in  in
If the switch does not accept named ACL create a numbered ACL
ip access-list extended 100
90 deny ip any any
line vty 0 4
 access-class  100   in
Hello thanks for the reply.
I forgot to mention this config is on the Core Switch on x.x.68.2. if i try to SSH to x.x.68.3 i get to the splash page however the password is not accepted( Access Denied).  Removing ACL from the interface on the CORE allows me in.
 Which device is x.x.68.3 ?  Are you using TACACS ?
Core is a 9500 on 68.2.
68.3 is a C9200L
we are using local Login
Login local
Do you conifg
Username xxxx password yyyy ?
Her is the User config
version 17.6
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
service call-home
service unsupported-transceiver
platform punt-keepalive disable-kernel-core
hostname Core
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
enable secret 9 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec default local
aaa session-id common
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
switch 1 provision c9500-16x
switch 2 provision c9500-16x
stackwise-virtual
domain 1
login on-success log
vtp domain Test.Local
vtp mode transparent
udld aggressive
license boot level network-advantage addon dna-advantage
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
spanning-tree vlan 100-106,200,998-999 priority 4096
memory free low-watermark processor 133114
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause loopback
errdisable recovery interval 30
username Redacted privilege 15 secret 9 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
redundancy
mode sso
Use
