sso NAC problem
abdelilah
Visitor
hi community,
we encountered a problem with sso NAC with some VIP users who use wireless and wired connexion (on windows 7) when a user switch from wireless to wired he has the authentication pop-up to reenter his login/password, which is not confortable. i found in a guide document about sso that "The CAS and Agent do not support using multiple NICs on the client machine. The client machine Wireless NIC must be turned OFF when the Wired NIC is turned ON." is there a way to bypass this and use sso with both wireless and wired connexion. Note that we have In boundimplementation for wireless and OOB for wired.
Many thanks in advance
Jatin Katyal
I agree with you Abdeleilah this is a major inconvenience to users that move back and forth to meetings.
I found an internal defect on the same problem.
CSCti08612    credentials are lost when switching between wireless SSO and wired
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
