strange problem with command authorisation on acs
sebastan_bach
Level 8
Level 8
hi i am having problem with command authorisation with acs. i am having a full version of acs 3.3
i have configured my router like this.
R1
aaa new-model
aaa authentication login default none
aaa authentication login john default group tacacs+
aaa authorization console
aaa authorization exec bob group tacacs+
aaa authroization commands 5 bob group tacacs+
aaa authroization commands 15 bob group tacacs+
line vty 0 4
login authentication john
authorization commands 15 bob
on the acs i have specified per user shell command authorisation and i have created 2 users
john and bob
john is configured with level 15
unmatched commands are permitted with unmatched arguments
bob is the level 5 user configured with
unmatched commands (deny)
add command configure
arguments permit terminal
unmatched arguments (deny)
john gets authenticated and authroisaed properly.
bob get authenticated and authorised properly as level 5 user
but he can't see the configure command in the exec mode
when he triies to execute the command configure
in the debug
av-user=bob
av-service=shell
av-cmd=connect
av-cmd-arg=configure
i tried the same with john
av-user=john
av-service=shell
av-user=configure
av-cmd-arg=terminal
when the request is sent from the user john it show service none privilege=15
but for user bob it shows
why the command is showing as connect and the arg as configure for user bob. i am got no idea abt this. and it is working fine for john. what could be the problem can anyone help me with this pls.i have working a lot on this to get this working .
sebastan
6 Replies 6
darpotter
Level 10
Level 10
I could be off target here... but you seem to be using priv levels AND per command authorisation.
I've always thought it was either/or ?
hi there can u helpe me with my problem. i am frustrated with the cisco acs. i did everything as per the guidelines and still it doesn't work. pls help
sebastan
Are you assigning user priv levels via the priv_level attribute (for the shell service) or via the enable login?
If you want per-command authorisation you could try doing away with all the priv-lvl stuff for commands.
Just enable the appropriate cmds/arguments for each user and try that.
Darran
hi darran u mean to say i have configure the privilege levels for users locally on the router for moving the commands from one privilege level to the other. is this what u are suggesting. waiting for ur reply.
sebastan
Well it depends on what you're trying to achieve.
You do away with privilege levels and do it all via command authorisation. Or, you vice versa.
Are you trying authorise only those commands that are above a certain priv level?
hi potter. i learned one thing that we can only authorise commands with acs but we cannot move commands from one privilege level to the other from the acs directly.we have to move the commands first from the with the privilege command on the router locally then only i can authorise the commands for the user at that privilege level.
sebastan
