Third-Party NAD Redirection Problem on ISE 2.2
mahdi.rashgi
Dear Colleagues
There is a scenario for using ISE 2.2 as guest portal for my wireless network that is consist of cisco WLC and old Proxim APs, I want to use new Feature of ISE referring as Authentication VLAN, so I create a new NAD Profile, and define VLAN, DHCP Server ,.. .The MAB is working well and the clients received ip address from ISE DHCP but redirection does not work.  I guessed the problem is in binding the guest portal with authentication VLAN, So I used both static URL Option as mentioned in below document and Not Supported option in NAD Profile but the result was unsuccessful, I would be thankful with your solution:
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-21/200604-Configure-Third-Party-NAD-Redirection-on.html
Best Regards
0 Replies 0
